If I encode a SVCD to DVD using DVD-Lab does it convert it into a TRUE DVD Format and not a SVCD-DVD?
If not, Do I need to change the files first then use DVD-LAB to convert to DVD?
I am looking for a way to make a TRUE DVDR!!!!!
Why are the best things things in life cost the most money?
Who stole the rest of my Signature, Own up, it was you, yeah you, thats it I am gonna come over there and .......... -
DVDLab does not have an encoding engine. It encodes nothing. If you insert mpeg2 480x480 it will author a pseudo DVD disc, not a full standards DVD. This will only play on (some) players that support SVCD discs in the first place.
If you really want to convert the SVCD to DVD then you must re-encode. I suggest TMPGEnc it is very good at re-encoding SVCD video. -
What about just patching the whole file instead of re-encoding it?
Is there anything quicker than TMPEGEnc like Mpeg Encoder by mainconceptWhy are the best things things in life cost the most money?
DVD Lab question
By sumeshkri in forum Authoring (DVD)Replies: 5Last Post: 13th Nov 2008, 21:32 -
DVD Lab PRO2 question
By mvp in forum Authoring (DVD)Replies: 9Last Post: 20th Apr 2008, 20:28 -
Question for those that use DVD-Lab Pro
By PharmBoy in forum Authoring (DVD)Replies: 2Last Post: 16th Apr 2008, 22:26 -
dvd lab question
By sumeshkri in forum Newbie / General discussionsReplies: 1Last Post: 11th Feb 2008, 22:44 -
DVD Lab question
By rizay in forum ComputerReplies: 7Last Post: 7th Dec 2007, 19:13
