Results 1 to 9 of 9
  1. Name ur best SVCD program.
  2. Member volswagn's Avatar
    Farmingville, NY
    TMPEGEnc... No doubt about it...
  3. Yep, no doubt. i posted a guide on these forums on how to create a great looking SVCD with TMPGEnc
    May 2001
    chicago
    CCE
    Tmpgenc would be my second choice
  5. The best program to make svcd is DVD2SVCD, no doubt....
    Jan 2001
    Vancouver/Portland
    CCE is the best for quality and speed (big speed difference!).
    TMGPEnc is best if using filters such as resizing, noise reduction, etc.
    Feb 2001
    Berlin, Germany
    CCE is the best in quality at low average bitrates. But you may want to use some more passes, so the speed difference isn't that big compared to TMPG.
    I don't recommend TMPG to resize, but Avisynth or VirtualDub.
    But sure, you can use TMPG's filters and cce encoder.
    DVD2SVCD uses the CCE encoder too, but using this all-in-one tool you loose the flexibility of the several tools. I prefer to use every tool as a standalone one.
    The easiest to use is probably TMPG.
  8. The Old One SatStorm's Avatar
    Hellas (Greece), E.U.
    My vote goes to TMPEGenc 12H and only 12H
    For re - encoding, is the best solution.
    (sat rips/DVD rips/Divx to (x)VCD/(x)SVCD/CVD/sDVD)
    For Avi to mpeg, cinemacraft and TMPEG 12H are equal. Expecially if you know to set right TMPEG....
    Cinemcraft is faster of course, but TMPEG overall is better.
    The main problem with TMPEG is I thing with Interlace/De-interlace filters. They need work. With Cinemacraft, the interlace thing works much better. And this is important to avi sources.
  9. hmm, why ONLY 12H? give us some insight on why 12H is superior to all other versions. You say 'Expecially if you know to set right TMPEG.... '. Give us some insight into the settings you use! ive looked ALOT into that myself and ive found alot of alternatives, but input would still be good!
