I have various vcd i created earlier and wanted to burn them on dvd-vcd. Now the problem is Tmpeg Dvd author gives me this error
and I want to bypass it without re-encoding is it possible and if it is then how do I do it
I've seen that screen in TMPGEnc Author but it's been a while. If I remember correctly there's an option (below the part on the partial screen you posted) that lets you have TMPGEnc Author fix the problem.
hmm the only button i saw was a ignore button and it was greyed out to
thanks -
I did exactly that before my post, but sometimes the mpg is stuffed and tmpeg gives up mid way. Anyway thanks for the suggestion, much appreaciated.
New TMPGEnc DVD Author Question
By Robert Simandl in forum Authoring (DVD)Replies: 1Last Post: 11th Jun 2008, 08:47 -
Tmpeg DVD Author doesn't like low quality captures?
By the wordsmith in forum Video ConversionReplies: 9Last Post: 20th Mar 2008, 07:30 -
Does TMPEG DVD author support multi VTS
By perfection in forum Authoring (DVD)Replies: 1Last Post: 31st Aug 2007, 17:19 -
why subtitles move with TMPEG DVD Author
By Konde in forum Authoring (DVD)Replies: 0Last Post: 22nd Jul 2007, 01:21 -
Trouble with TMPEG DVD Author
By acidcrash in forum Authoring (DVD)Replies: 3Last Post: 20th Jul 2007, 05:31
