My burner burns the dvds fine, and sayss there's no problem, but when verifying, there is some trouble. Also when trying to read the disc, the first half is readable, then the files are corrupt.
Tried on several disc medias.
This happens when im burning data DVDrs from harddrive.
Is the burner faulty?
Most likely, it's the disks you are using, get a quality DVD+RW or DVD-RW disk or two and do the same burn. Make sure you run it in DMA mode.
Something to look at at first.....
Burnin DVD via Flick, all DVD clips come out pixilated towards end of disc?
By jacknscoob in forum Authoring (DVD)Replies: 27Last Post: 28th Jan 2012, 07:48 -
Could not perform end of Disc-at-once
By smt16 in forum DVD RippingReplies: 1Last Post: 18th Jun 2010, 06:50 -
Could not perform end of disc-at-once on dual layer dvd only
By Subhash in forum DVD & Blu-ray WritersReplies: 20Last Post: 25th May 2009, 14:09 -
By mrjoetoff in forum Newbie / General discussionsReplies: 2Last Post: 10th Sep 2008, 14:27 -
Help Burning a disc fails at 1%
By DuBsTaR in forum Newbie / General discussionsReplies: 7Last Post: 7th Jun 2007, 18:16
