I've brought my Pioneer A05 about 6 months ago for $180 and now the dual Pioneer A06 is around $130.
Because the dual drives are out, 8.5 DVD burners will be shipping soon, and blue-ray technology is about to spawn. They are trying to unload their DVD-R inventories before they get stuck with them.
Hello. -
http://www.newegg.com/app/ViewProduct.asp?submit=manufactory&catalog=5&manufactory=116...tby=14&order=1
why is this DVR-106D $135 and the other DVR-A06USPK4 for $168? They are both dual and it shoud be the same model. 106 = A06. -
'cos one is OEM - bare drive only, while the other is RETAIL, e.g. it comes with cable, screws, manual, sample blank DVDs....
one is the OEM version (Original Equipment Manufacturer), so it's a bare-bones drive in a white box with (possibly) limited software.
the other is the retail box, like you'd buy off the shelf at the local superstore.
EDIT - Dubber beat me by 6 minutes...
double check the description - it's possible that the only difference between the OEM and Retail versions is the box - some OEM versions will have the same software disc, special cables, etc., some won't.- housepig
Housepig Records
out now:
Various Artists "Six Doors"
Unicorn "Playing With Light"
blu-ray drive, cheap but decent
By BroomQueen in forum Blu-ray RippingReplies: 7Last Post: 13th Jun 2011, 23:08 -
DVD exploding inside the drive from a drive exceeding 24x. True?
By snafubaby in forum MediaReplies: 10Last Post: 5th Dec 2010, 19:05 -
Cannot burn to a DVD disc and DVD RW-drive changed to CD-drive after copy
By coody in forum DVD & Blu-ray WritersReplies: 0Last Post: 13th Sep 2009, 05:18 -
Time/Date Stamp - DVD, Hard Drive, and/or flash drive camcorders
By vanjh9 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 2nd Feb 2009, 19:38 -
What drive(s) CAN reliably burn cheap 8x DL media?
By miamicanes in forum DVD & Blu-ray WritersReplies: 20Last Post: 16th Feb 2008, 20:09
