I'm a linux geek, and if possible, would like to use linux for capturing/encoding/authoring/burning.
I've been doing some reading, and while it appears that the dvd authoring tools are in their infancy, all the other functionality is available now.
One question: how does the quality of the end product compare to using the usual Windows tools (ie. tmpgenc, dvdlab, etc)?
If I'm going to invest the time in learning the unix tools, I don't want to be disappointed with the results.
Thanks!
the results are ok -- encoding is not as good though and the number of tools is GREATLY reduced ...
MainActor 5 for linux can be downloaded from main concept web site -- it will do the editing and encoding and capture portion"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
Mac Or Linux Users - Who's Worse?
By hech54 in forum ComputerReplies: 9Last Post: 2nd Oct 2011, 20:25 -
Attn: All Premiere Pro experts!
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 1Last Post: 1st Sep 2010, 04:30 -
Update- So what programs do you use? (attn newbies too)
By Super Warrior in forum DVD RippingReplies: 6Last Post: 12th Jan 2009, 13:45 -
Linux themed skin for DVD Rebuilder (for Ubuntu and Generic Linux)
By freebird73717 in forum LinuxReplies: 5Last Post: 26th Nov 2008, 21:27 -
Nero Linux 3 Delivers Blu-ray and HD DVD Data Burning Support to Linux OS
By BJ_M in forum Latest Video NewsReplies: 0Last Post: 28th May 2007, 11:23
