I would like to clearly understand the process of ripping one VOB from a DVD, and converting it to AVI so as to be able to edit it in Premiere v6.
I have already spent a substantial amount of time on this but I suppose I am still missing something.
I am using DVD Decrypter to rip the VOB from the DVD to my hard drive.
In DVD Decrypter I am using all default settings. No problems so far.
I use Virtualdub-MPEG2 and this guide:
https://www.videohelp.com/avi2divx.htm
In this guide, it specifically states to use Video->Fast recompress and explains why to not use full processing, so I use Fast recompress.
I select Audio->Full processing.
I select Video->Compression.
For Video Compression, I have been selecting Huffyuv. I have selected other codecs but have received the same failure.
I select Audio->Compression
For Audio Compression, I have been selecting MPEG Layer 3. I have selected other codecs but have received the same failure.
I select File->Save AVI and the process runs to completion. I now have a AVI that I can watch using MS Media Player.
The problem is when I try to use the AVI in Premiere v6. I can import the AVI and even see a few frames in the preview window, but after just a few mouse clicks, Premiere crashes.
What am I doing wrong? Is there a guide that list the process of converting a DVD VOB to a AVI that is compatible with Premiere v6?
I would really appreciate some help with this or perhaps even a reference to where I could find some help.
You can try this, Download Canapus DV-encoder here:
https://www.videohelp.com/tools?tool=192#comments
Then load the vob into Vdub, choose the canapus DV-Codec for the output AVI. Premiere should work with this easily.
Good luck.Got my retirement plans all set. Looks like I only have to work another 5 years after I die........
Combining VOB & AC3 to DV AVI Files for Editing in Premiere Pro CS4
By foochuck in forum Video ConversionReplies: 2Last Post: 10th Jul 2010, 14:08 -
VOB to AVI to import into Premiere CS3
By newcomer1 in forum DVD RippingReplies: 6Last Post: 11th Mar 2009, 15:32 -
VOB to DV-AVI to Premiere - Yes, I have done my homework
By bpalmer in forum Video ConversionReplies: 14Last Post: 9th Mar 2009, 22:47 -
Converting VOB to DV AVI for Premiere 6.0
By wasimismail in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 22Last Post: 9th May 2008, 22:20 -
Premiere Crashes on 720 P 25 capture
By Dejablues in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 25th Oct 2007, 10:14
