Does anyone know where I can get sound effects from the movie Predator (1 or 2, it really doesn't matter)? I looked online for some soundboard, but no luck (it was a long shot anyway). I'm thinking of 2 ways i can get the sounds...
1. Rip from the DVD - but this will leave some music behind the sounds, which I don't want.
2. Rip from one of the video games (Alien vs. Predator 1 or 2). Unfortunately, I don't know how I can do this.
Does anyone know where I can find some of the sound effects, or tell me how to get the sounds from the game?
Thanks.
Unfortunately, the game is on PC, so I can't connect the video game system directly to the computer.
Nice idea though. -
Well, you can always run your speaker audio into your mic input and record the mic input.
Hello. -
Ok, so I could just plug my speaker output into the "mic in" and it should work? Would using the simple Windows Sound Recorder do the job?
are the predator games on any of the cartridge consoles? because if so you could use an emulator to run the rom and do a wav output and get your sound effects that way.
Do you have any sound recording software?
Simple as can be, get a cable with the mini din pin on both ends, plug one into your speaker jack, the other to your sound card line in, play sound, record sound
Also you could even get a double plug for the speaker jack so your speakers are still connected so you can hear what you are recording
Should cost maybe $5 for a double plug and cable to do this, maybe less.
Not sure what I paid for mine. Wallmart or K-mart should have it, if not Radio shack does. -
Thanks for the help!
Help! When I render a video in Adobe After effects, theres no sound!??!?!
By Devilsadvocate in forum EditingReplies: 4Last Post: 21st Mar 2012, 09:02 -
How do I Rip sound effects and music separately?
By tapir in forum DVD RippingReplies: 9Last Post: 19th May 2010, 01:04 -
How to find moive sound effects?
By squeejiboo in forum Off topicReplies: 2Last Post: 29th Aug 2008, 07:04 -
Vegas Movie Studio 8 Platinum Music/Sound effects
By Nuke Shower in forum AudioReplies: 3Last Post: 21st Apr 2008, 00:58 -
Sound Card Compatibility with After Effects CS3 Issue...
By Angelus22 in forum EditingReplies: 1Last Post: 28th Oct 2007, 07:20
