I have a problem when converting a divx to a vcd with tempgenc. The movie becomes unsharp (blurry, i dont know the right word it is unscharf).Just a little bit.Its not like you cant see anything but when you watch 18 hours a day you should get your eyes renewedI guess it is just a little change in the settings.
Thanx to all who reply and to all others that help people.
Results 1 to 1 of 1
Multiple Files & Resolutions In Tempgenc Xpress 4
By TufrThanu in forum Video ConversionReplies: 0Last Post: 9th Aug 2009, 14:21 -
error while burning DVD DL using tempgenc dvd author
By rgpai9972 in forum Authoring (DVD)Replies: 2Last Post: 2nd Jun 2009, 21:15 -
tempgenc authoring works 4 - can I save the edited clips?
By yvonne_1980 in forum Authoring (DVD)Replies: 2Last Post: 24th Mar 2009, 05:59 -
Tempgenc DVD Author small file
By EPLindblom in forum Authoring (DVD)Replies: 1Last Post: 13th Feb 2008, 21:39 -
problem with tempgenc plus
By lancerx in forum Newbie / General discussionsReplies: 7Last Post: 6th Dec 2007, 01:35
