  1. Bill H
    Guest
    I have created numerous excellent 2,3 and 4 film DVDs using SVCD2DVD, but just recently I am having a problem where two of the three films are OK, with the third playing 3-4 secs then returning to the beginning. This happens when played in a standalone (tried two different ones, so it's not the player) some of the discs play OK on my PC using PowerDVD, some don't play. I was using Nero to burn which I previously had no problems with and have since tried burning with the burn tool from DVDlabs with the same problem
    Any ideas???
    Bill
  2. allynn
    Guest
    I've had the same problem only it's always the first film that loops, i can get round this by using search and entering a time say 50secs into the film and it plays alright from there but its still annoying that it doesn't work. Would appreciate any help .
  3. same here...happened after the latest update(not the one I reported on Nov 18, 2003 12:52 the one after) was ok before the latest update.
    Here's a log file from a single music video file I ran through svcd2dvd:
    Starting SVCD2DVD: v1.5.1418.14919
    Begin time: 01:27:01
    ******** Ripping SVCD images to get mpegs
    Analysing File: F:\Shakira _ Suerte.mpg
    ++ WARN: mpeg user scan data: one or more BCD fields out of range for 'forward_I_offset ': [00:0a.0a]
    ++ WARN: mpeg user scan data: one or more BCD fields out of range for 'forward_I_offset ': [00:0a.0c]
    ++ WARN: mpeg user scan data: one or more BCD fields out of range for 'forward_I_offset ': [00:0a.13]
    ++ WARN: mpeg user scan data: one or more BCD fields out of range for 'backward_I_offset': [00:03.3a]
    ++ WARN: mpeg user scan data: one or more BCD fields out of range for 'forward_I_offset ': [00:0a.14]
    ++ WARN: mpeg user scan data: one or more BCD fields out of range for 'forward_I_offset ': [00:0a.1d]
    ++ WARN: packet length beyond buffer (pos = 20 + size = 2304 > buflen = 452) -- stream may be truncated or packet length > 2324 bytes!
    ++ WARN: bad packet at packet #451 (stream byte offset 1048124) -- remaining 452 bytes of stream will be ignored
    -->Processing 1 mpeg files.
    ############### New MPEG File ###############
    Type: SVCD
    Horizontal Res: 480
    Standard: NTSC
    Audio SampleRate: 44100
    ******** Demultipexing original mpg file
    (Total size: 64MB, Duration: 00:00:05, Rate(MB/Min): 710.09)
    ******** Resampling audio from 44.1 KHz to 48 KHz
    (Total size: 5MB, Duration: 00:00:07, Rate(MB/Min): 41.38)
    ******** Multipexing elementry streams
    INFO: [???] mplex version 2.2.2 ($Date: 2003/05/13 20:27:15 $)
    INFO: [???] File F:\Shakira _ Suerte_DVD.mpv looks like an MPEG Video stream.
    INFO: [???] File F:\Shakira _ Suerte_DVD.mpa looks like an MPEG Audio stream.
    INFO: [???] Video stream 0: profile 8 selected - ignoring non-standard options!
    INFO: [???] Found 1 audio streams and 1 video streams
    INFO: [???] Selecting dvdauthor DVD output profile
    INFO: [???] Multiplexing video program stream!
    INFO: [???] Scanning for header info: Video stream e0 (F:\Shakira _ Suerte_DVD.mpv)
    INFO: [???] VIDEO STREAM: e0
    INFO: [???] Frame width : 480
    INFO: [???] Frame height : 480
    INFO: [???] Aspect ratio : 4:3 display
    INFO: [???] Picture rate : 29.970 frames/sec
    INFO: [???] Bit rate : 2520000 bits/sec
    INFO: [???] Vbv buffer size : 114688 bytes
    INFO: [???] CSPF : 0
    INFO: [???] Scanning for header info: Audio stream c0 (F:\Shakira _ Suerte_DVD.mpa)
    INFO: [???] MPEG AUDIO STREAM: c0
    INFO: [???] Audio version : 1.0
    INFO: [???] Layer : 2
    INFO: [???] CRC checksums : no
    INFO: [???] Bit rate : 28672 bytes/sec (224 kbit/sec)
    INFO: [???] Frequency : 48000 Hz
    INFO: [???] Mode : 0 stereo
    INFO: [???] Mode extension : 0
    INFO: [???] Copyright bit : 0 no copyright
    INFO: [???] Original/Copy : 1 original
    INFO: [???] Emphasis : 0 none
    INFO: [???] SYSTEMS/PROGRAM stream:
    INFO: [???] rough-guess multiplexed stream data rate : 2791848
    INFO: [???] target data-rate specified : 10080000
    INFO: [???] Setting specified specified data rate: 10080000
    INFO: [???] Run-in Sectors = 89 Video delay = 13019 Audio delay = 0
    INFO: [???] New sequence commences...
    INFO: [???] Video e0: buf= 237568 frame=000000 sector=00000000
    INFO: [???] Audio c0: buf= 4096 frame=000000 sector=00000000
    INFO: [???] Scanned to end AU 6007
    INFO: [???] STREAM e0 completed @ frame 6007.
    ++ WARN: [???] Discarding incomplete final frame MPEG audio stream c0!
    INFO: [???] STREAM c0 completed @ frame 8351.
    INFO: [???] Multiplex completion at SCR=18045805.
    INFO: [???] Video e0: buf= 236730 frame=006007 sector=00030042
    INFO: [???] Audio c0: buf= 1408 frame=008351 sector=00002779
    INFO: [???] VIDEO_STATISTICS: e0
    INFO: [???] Video Stream length: 60531738 bytes
    INFO: [???] Sequence headers: 1
    INFO: [???] Sequence ends : 1
    INFO: [???] No. Pictures : 6007
    INFO: [???] No. Groups : 300
    INFO: [???] No. I Frames : 300 avg. size 49593 bytes
    INFO: [???] No. P Frames : 1439 avg. size 17830 bytes
    INFO: [???] No. B Frames : 4269 avg. size 4684 bytes
    INFO: [???] Average bit-rate : 2415200 bits/sec
    INFO: [???] Peak bit-rate : 4552000 bits/sec
    INFO: [???] BUFFERING min 15 Buf max 134306
    INFO: [???] AUDIO_STATISTICS: c0
    INFO: [???] Audio stream length 5612548 bytes.
    INFO: [???] Syncwords : 8353
    INFO: [???] Frames : 8353 padded
    INFO: [???] Frames : 0 unpadded
    INFO: [???] BUFFERING min 15 Buf max 683
    INFO: [???] MUX STATUS: no under-runs detected.
    (Total size: 64MB, Duration: 00:00:05, Rate(MB/Min): 671.54)
    Analysing File: F:\Shakira _ Suerte_DVD.mpg
    ++ WARN: mpeg stream will be padded on the fly -- hope that's ok for you!
    ++ WARN: autopadding requires to insert additional 141036 zero bytes into MPEG stream (due to 511 unaligned packets of 512 total)
    ******** Creating DVD Folders...
    Creating VTS #1
    SVCD2DVD: DVDfolders
    Generating DVD folders please wait....
    -->: DVDFolders creating VTS
    -->: VTS 02
    STAT: Processing F:\Shakira _ Suerte_DVD.mpg...
    (Total size: 64MB, Duration: 00:00:03, Rate(MB/Min): 1,190.83)
    ============ Complete ============
    ============ Duration: 00:00:22
    This particular video the sound worked on, but the video froze.
    Before the latest update a dvd filled to the brim took 35 min. Speed improvement is spectacular
  4. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    Hey semi. Do you want to upload that file to my ftp?
    ftp://svcd2dvd:Upload@ftp.svcd2dvdmpg.com:7676/semi/
  5. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    Mmm - set svcd2dvd on it & got the results in VIDEO_TS.zip (have a look)
    Works fine for me....
    Did it play ok on your PC with PowerPC/WinDVD?
    Could it be down to your media or player?
    BTW took 34 secs for me!
  6. reinstalled...works fine now..once again nice speed improvements
    svcd2dvd "vanilla" (without ffmpeg mpgtx and mplexwin32) took 2min and 35 sec
  7. Bill H
    Guest
    Just did another four films on one DVD, first three perfect, fourth one loops at the beginning only on my standalone, works perfect on PowerDVD. Previous disc had six episodes of Sopranos on and was perfect, doesn't seem to be any consistency.
