  1. I captured from dvcamcorder by firewire with scenalyzer to an avi file, then used tmpgenc plus 2.5 to encode to m2v&wav files using the wizard for DVD. I then took the wave file and converted to ac3 and when adding m2v file to Tmpgenc DVD gives me this error "The video sequence header is incorrect. A video sequence header is necessary for every GOP in a standard DVD"
    Reel DVD won't even accept the file, NeroVision 2e just freezes.
    The m2v file is 704x480 , interlaced, and used 2-Pass VBR for encoding. I've done this 4 times and got really good dvds, but this time I don't know what happened. The only difference from the other files I used on the other dvds, is that the others are 720x480. Is this the problem?
    My question, is this fixable? and How can I do this?
    Thx in advance. Please help, cause I deleted the original avi from computer and dvcamcorder!!
  2. Member daamon's Avatar
    Melbourne, Oz
    Hi,
    I'm having the same problem.
    I've done a fair bit of hunting, and found these in the forum:
    https://www.videohelp.com/forum/viewtopic.php?p=457610&highlight=header+gop#457610
    https://www.videohelp.com/forum/viewtopic.php?p=526308&highlight=header+gop#526308
    http://www.lordsmurf.com/convert/tmpgenc/tmpgencplus.htm
    I don't know if they'll help as I've only found them today (I shall try when home), but I thought I'd let you know as I notice that there's been no replies to your post.
    Good luck...
    There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
    Carpe diem.
    If you're not living on the edge, you're taking up too much room.
