  1. Please can some1 help me out, Been haveing this prob for like 2 weeks now and still havent found a way round it.... i got a few svcds which i wonna put onto dvd so i join the mpegs 2gether with TMPGEnc but wen i join mpeg2 files 2gether which habve 48k audio the output file is always out of sync realbad..... i tryed filemerge which worked but wen i put the mpeg into dvd lab it only did 59% then got errors.. can some1 please help me.... i really need ur help... thanx
  2. I've never used it, but a lot of people say Womble MPEG-VCR is much better than TMPGEnc at cutting/joining MPEG-2.
    Many people have had the same problem as you with sync issues if they use TMPGEnc to do this - try searching the forums.
    cheers,
    mcdruid
    Mar 2003
    Uranus
    Have you considered just adding your MPEG2 files to the authoring
    program separately ? They can be made to play in order.
  4. Originally Posted by FOO
    Im not sure if you can do that in dvd lab
  5. FOO..... I did wot u said and it worked.. i just made part 2 play right after part 1 in dvdlab.. thanx mate
