How do I know if a DVD is DVD9 or DVD5? Sry for the noob question.
Run it through DVD Shrink. It will tell you how many GB it has.
Hello. -
There are a few ways:
First the obvious Check the box that the DVD came in If it says 'dual layer' then its a DVD9 (I have also come across a DVD14 disc 'The Piano')
Next check the DVD its self again your looking for 'dual layer'
Ok, and now for the ways to tell when your using a program.
- If the total file size is more then 5GB then it's a DVD9(or higher)
Hope I helped some...Total Dew U points : 392 0 pending
-(PC)- (for sale!!!)
GA-K8vt800(Pro)
AMD 64 3200+
1280mb DDR400
120GB SATA
20GB EIDE
DVR-A06 FW 1.07
-(XBOX)-
Looking for a X2.3pro modded box...
PM if you have one FS -
When I don't know if a DVD is single or dual layer I just pop it in my DVD-ROM drive and start up DVD DECRYPTER in ISO READ MODE.
It will then tell you if it is 1 or 2 layers.
looooook reallllly close you can see the layers.
put it in the dvd drive, click on the drive properties of your drive, ie d, e , f and see how large the disc is. -
Dual layered discs (DVD-9) are gold in colour. Single layered discs (DVD-5) are silver.
Originally Posted by bluntman72
jbcandkcI'm just sitting here watching the wheels go round and round.
-John Lennon
DVD9 to DVD5
By roflwaffle in forum DVD RippingReplies: 5Last Post: 3rd Nov 2010, 16:52 -
The best possible quality of DVD9 to DVD5
By Charmer in forum DVD RippingReplies: 37Last Post: 28th Apr 2010, 19:00 -
DVD5 vs. DVD9
By Beaker14 in forum DVD RippingReplies: 1Last Post: 6th Nov 2009, 10:33 -
DVD9 To DVD5
By taylor6698 in forum DVD RippingReplies: 3Last Post: 22nd Oct 2007, 20:36 -
dvd9 to dvd5 using dvdshrink
By rancid in forum DVD RippingReplies: 7Last Post: 14th May 2007, 21:52
