  1. Ok, I'm using ATI Tvwonder capture card, I'm just wondering if there's a better software than ATI's MMC to capture to mpeg, the only problem I'm gettin' to the output captured file is too big! .. is there any better softwares with compression filters or somethin'? or mpeg's can't be compressed? .. Thanks!
  2. i have read from many others on here about what their favorites are and i've tried just about all of them. i have the ATI card and for me MMC has worked the best for me but thats my personal preference. i capture AVI Huffyuv codec and its usually 12 minutes=4 gigs. look to the left in the TOOLS section. it has a list of other capture software that you can try......
    May 2001
    chicago
    I use powervcr 3 to do my capturing and it's flawless!
