hi i brought a programe called pictures to tv 1.2, so i could do a vcd of jpegs to play on a home dvd player, prob is it puts a small add on the cd which makes my show item 2 on the cdis there a way of burning the cd and leaving out the add so my show will be item 1 on the cd? .
or maybe theres another programe that i can get that will do it , it would be cool if it also auto played on the dvd player as well . cheers for any help![]()
Try looking at these guides for info on how to make slideshow VCD's.
cheers,
mcdruid. -
cheers , the slideshow vcd i created with 258 pics an 10 sound tracks works great ,but as the programe put it add first and my slide show second my slideshow doesnt auto play , the add does,
just wondered if you can get rid of the add before ripping , or a better programe with no adds.
The guides have details of several other apps you can use - you only have to look on the right hand side to see which apps each guide uses.
VCDEasy is mentioned, and the freeware version of that is still available (see the Tools section). It wouldn't put any ads or logos on your slideshow.
There are other tools there too.
cheers,
mcdruid. -
i also have used proshow gold, it is really good, i made a long show with it and had a load of mp3 music tracks on it, i would definately reccommend a download of it.
Problems with a VCD? A somwehat odd way of converting VCD to DVD
By dvd3500 in forum Video ConversionReplies: 2Last Post: 19th Oct 2007, 07:54 -
Convert NTSC AVI, DVD, (S)VCD to PAL DVD, (S)VCD
By scratchman in forum User guidesReplies: 14Last Post: 4th Jun 2007, 02:36
