i have an mpeg1 movie file which i ripped off a vcd using isobuster, what i want to do is convert this mpeg 1 movie to be dvd compliant and put it on to a dvd+r. i dont want to burn and keep it mpeg1 as i want to be able to send the finished dvd disc to my neice who at present only has a cheap dvd player which does not play vcd or mpeg1. how would i make the dvd using this mpeg 1 file bearing in mind the above?
VCD video is DVD compliant, meaning it can be put to DVD as is. VCD audio is 44.KHz sampling rate which is not fully DVD compliant, but will still play in many DVD players. If you want to ensure full compatibility then you need to resample the audio from 44.1 KHz to 48 KHz. then author and burn. There's several guides which can give you all the required steps, right here.
Good luck."Art is making something out of nothing and selling it." - Frank Zappa -
but i want to send the finished dvd to my niece and her dvd player does not play normal vcd or svcd, so will this still work on here dvd player?
It may or may not work on her player. heck, even a "complient" dvd may not work on her dvd player.
You could do what Zippy said, or take the mpeg1, send it thru tmpge to make it an mpeg 2 (with 48khz), then author it in dvd author, burn iyt with dvd author and ur done. I would get the name and model of her dvd player then check the players list to see if it works with +R discs. -
ok cool, i will try doing what he suggested, i know she can play dvd+r cos i sent her some dvd+r discs before and they played ok so thats cool.
cheers
want to capture directly to ffdshow mpeg-1 or mpeg-2 for dvd
By wolfdogg in forum Capturing and VCRReplies: 10Last Post: 10th Jan 2012, 07:23 -
DVD to an edited MPEG-2 file with MPEG audio: Trouble/please help
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 21Last Post: 9th Aug 2011, 08:52 -
This is a minefield! (converting mpeg to mpeg for DVD)
By uth in forum LinuxReplies: 29Last Post: 18th Nov 2007, 15:04 -
MPEG-1 to MPEG-2 to DVD Advantages/Disadvantages?
By louv68 in forum Video ConversionReplies: 4Last Post: 7th Jul 2007, 16:51
