It came free with my dvd-ram drive. There are essentially no reviews of it in the tools section.
Anybody have any comments on it? I just don't want to waste my time learning how to use it if it's junk.
Thanks.
I have DVDit! PE, and it's the only authoring program I use now. The important features for me are its ability to encode Dolby Digital soundtracks, and to import menus created in Photoshop. It can create 4:3 and 16x9 DVDs, as well as the ubiquitous VCD. It can also create a DVD using mpeg-1 files (I fit the complete Thundarr the Barbarian series on 2 DVD-R's this way).
Tried DVDit. Runs slow on my Pentium III 935 mhz system. Worst problemis that there is no on screen feedback indicating progress of sequences, only the hour glass. Is there a setting to overcome this.
Kitchnerg -
the chapter point settings are very very fishy..
its a pretty good thing to use if you're making home made movies
subtitles with DVDit 6 PRO
By jakewoodblues in forum Authoring (DVD)Replies: 2Last Post: 16th Apr 2010, 14:51 -
Replacement for DVDit Pro HD 6.3 Final
By GrampaD in forum Authoring (Blu-ray)Replies: 2Last Post: 11th Oct 2009, 12:04 -
Subtitle Sync Problems in DVDit Pro
By aquaorbis in forum SubtitleReplies: 0Last Post: 5th May 2009, 23:40 -
Has anyone used Sonic Scenarist or DVDit pro HD?
By jbandy1 in forum Authoring (Blu-ray)Replies: 16Last Post: 18th Feb 2009, 02:08 -
DVDit Pro HD and Sript error in activation
By arturjose in forum Authoring (DVD)Replies: 1Last Post: 19th Nov 2007, 01:51
