i am trying to convert rm file to mpg and I am having some problems it says file is not supported. need help do I need to ad a codec. i have used nimo. ffdshow and some others nothing works .
Results 1 to 9 of 9
EO WILL NOT OPEN IT EITHER ANY OTHER SUGGESTIONS. It says it is not a valid folder. it says the extension is RM. But it is an mpeg video
Another alternative to EO is TINRA - which I find very good.
I think you will need Real Player (or perhaps Real Alternative) for either to work.
As an aside - I wouldn't use Nimo.. but you already have
cheers,
mcdruid. -
If it's an MPEG video already , why are you looking to convert it
to MPEG ? -
You need to figure what your source really is. Is it MPG or something else somehow renamed/confused as RM file?Originally Posted by vesterlee
EO Video comes with its own player, so it should not have any problem playing Real Movie file. If the file extension is RMVB, rename it to RM before feed it to EO Video.
TINRA is good for converting from RM to AVI, not to MPG. Unless you want to convert to AVI first, then MPG, but why the extra conversion???Originally Posted by theDruid -
You do need to have RealPlayer installed on your computer to convert an RM file to avi. However, tinra won't work unless you have RealPlayer 8 installed which you can find here:
http://forms.real.com/real/player/blackjack.html?src=serviceandsupport.
RealONE Player needs to be removed first, then install RealPlayer 8. Then, you should be able to convert an RM file with no problems. (Real Alternative does not work with tinra. I tried it already.) Any other questions, please ask.
See if it will play in VirtualDubMod or VdubMpg.
If so you are home free
How to convert to .mpg without failing?
By Grahamf in forum ffmpegX general discussionReplies: 2Last Post: 27th Mar 2011, 19:36 -
[help] TMPGENC DVD AUTHORING v3 - unable to convert to MPG
By meeya in forum Authoring (DVD)Replies: 3Last Post: 19th Dec 2008, 05:47 -
How can I convert MPG file recorded by progDVB into a regular MPG
By Aafour in forum DVB / IPTVReplies: 8Last Post: 16th Oct 2008, 14:51 -
how can i convert .mov to .mpg?
By johnnylonghair1 in forum MacReplies: 4Last Post: 6th Apr 2008, 12:30 -
Convert DVD TO MPG OR VOB TO MPG FOR FREE!!!!
By beetee123 in forum Video ConversionReplies: 9Last Post: 27th Jul 2007, 09:47
