  1. I downloaded the dvdlab trial last night, to author and burn a copy of a movie. The movie is already in mpg format, courtesy of tmpgenc.
    Anyway, I created my menus, and then hit "compile dvd". Apparently it was just about done creating the temporary vob file when I got an error, and the process came to a halt.
    Sorry, I don't remember the error offhand; it was late and I just went to bed after it happened.
    But I could tell that the vob file in the temporary files directory was just about done (about 4 GB of a 4.2 GB file).
    This is under winxp home edition. Anybody else have this problem?
    Thanks.
  2. Member housepig's Avatar
    Jan 2003
    the Plains of Leng
    without knowing what the error was, it's hard to say.
    can you replicate the error, and copy/paste what it said?
    - housepig
    Housepig Records
    out now:
    Various Artists "Six Doors"
    Unicorn "Playing With Light"
  3. Sure; I'll do it tonight.
    Oct 2003
    RATAE CORITANORVM
    Are you using NTFS or FAT32 file system? FAT32 has a 4gb limit. I'm not sure if DVD-Lab creates one big temp file during compile. It sounds like it does. If you do have FAT32 this could be the reason why it's failing at this point. I believe you can convert your volume to NTFS within WinXP.
  5. That was one of the first things I thought of, but the file system that I was using for the temp file was NTFS.
