Greetings everyone,
After shrinking my "wonderful days" IFO file by using DVD lab, and then burning it onto a DVD-RW using Nero (v.5.5.10.7), it finishes the process, and then at the very end it spits out an error, although the data is clearly on the DVD. The odd thing here is, that even though PowerDVD can't smee to play it normally (frameskipping + no audio), windows media player on the other hand can do so, without any problems at all (correct synch, audio, etc.)... I need to know what I did wrong, as the next step in my lttle scheme is to burn the same files onto a DVD-R and then play that via my Panasonic DMR-E30 (which supports no DVD-RW, as I recall).
So, in other words, if I burn it onto a DVD-R, will I be confronted with the Windows Media Player situation (which is good), or with the PowerDVD situation (which is bad, of course)
Any help would be deeply appreciated, as usual![]()
Results 1 to 1 of 1
Problem Playing Authored/Burned Dvd on DVD Player
By djgazzabhoy in forum Video ConversionReplies: 10Last Post: 24th Nov 2011, 15:15 -
Problem with recently burnt DVDs not reading suddenly in any player
By Xmetalfanx in forum DVD & Blu-ray WritersReplies: 2Last Post: 20th Jul 2011, 23:27 -
fast forwarding authored DVD causes sync problem
By snafubaby in forum Authoring (DVD)Replies: 3Last Post: 15th Feb 2010, 01:10 -
Samsung BP3600 problem playing Nero authored DVD's
By stonejg in forum DVD & Blu-ray PlayersReplies: 6Last Post: 10th Jan 2010, 13:56 -
Lipsync-problem with copy of authored DVD (TMPG-related)
By fedet123 in forum Authoring (DVD)Replies: 2Last Post: 10th Oct 2009, 20:01
