  1. Hi. I would like to place on DVD cca 60 music videos (mpeg2
    files,352x288,CBR). I would like to play them one after another and
    also like to browse between them by prev/next button. I have 2
    choices:
    - Author them as separate files. The videos really can be browsed by
    prev/next button, but it works only in my standalone DVD player
    (Samsung). In SW players (PowerDVD, WinDVD) the prev/next buttons
    don't do anything. I don't know who behaves properly - Samsung or SW
    players?
    - Merge them into one file and make chapters. This solution has one
    problem. First I had to find the right SW to do the merge - M2Edit .
    The TMPGenc refused some files, though they all had been encoded in
    TMPGenc, other simple utils produced unusable result. The problem is,
    that the I-frames are not exactly at positions, where the previous
    videos were merged - I can't point a chapter to first frame of former
    video. Also when making the chapters - something is wrong. I cannot
    step over the merging point, the timer gets confused. I must drag a
    slider a little forward and step back. Tried many authoring programs -
    DVD Workshop, DVD Movie Factory, DVD-lab. They all behave the same.
    I have 2 questions:
    - In separate files case - what is the right behavior of prev/next
    button ?
    - In single file case - can the files be merged so the I-frames start with
    every new merged video? If so, what utility can do this merge?
    Thanks.
  2. Member SaSi's Avatar
    Jan 2003
    Hellas
    The behaviour of the Next/Prev buttons depends on the way the DVD is authored. Certain DVD Players extend their behaviour and work properly with badly authored DVDs. To give an example, my settop player can accept a DVDR (ROM) with any mixture of MPEG-1 or MPEG-2 files recorded and will play them back one after another with next and previous skipping forward and backward. PowerDVD won't even recognise the disk.
    I believe the best approach for your task is to combine all the files into a single MPEG-2 file and author that with chapter points. Tmpgenc's Cut and Merge utility should accept all these MPEG files. The only reason I can guess for failure is that some files are MPEG-2 and others are MPEG-1. You can't concatenate the two.
    The more I learn, the more I come to realize how little it is I know.
