Can you use the InstantCopy Hidden Settings Editor in both v7.0 and v8.0 or just in v7.0?
Do you have InstantCopy under Reduction Method do "Automatic Resize" or just set it to "High Quality"
http://www.mrbass.org/instantcopy/
you can use ICHSE on both
I recommend you do all the settings manually in IC 8 and do not use auto resize. You also may want to check which audio/subs it is selecting
you can also specify different qualities for different titles on the DVD using IC 8, so you can use high quality on the movie and use speed on the extras
How to edit a Hidden PMT File
By alex69 in forum EditingReplies: 1Last Post: 24th Dec 2010, 00:42 -
Hidden Layers in Film
By Snuffy in forum Newbie / General discussionsReplies: 16Last Post: 18th Dec 2010, 10:30 -
How to display the hidden folder in My Documents?
By coody in forum ComputerReplies: 3Last Post: 9th Dec 2008, 05:40 -
can the file hidden?
By fkw81 in forum DVD RippingReplies: 3Last Post: 24th Sep 2008, 06:11 -
hidden videos being viewed
By zoobie in forum Newbie / General discussionsReplies: 11Last Post: 22nd Feb 2008, 05:31
