A couple of months ago i stopped using my nero 6.0.09 as when i created dvds it would have errors during the burn and wouldnt play the dvds sometime. I switched to stomp and had no problems
Does anyone know if you upgrade to the latest nero 6 with the updates on the website, if you can write dvds and play them without any problem asi dont wanna waste my dvds.
I used to burn my dvd movies using the dvd utf selection rather than the dvdvideo as the dvdvideo burning method wouldnt play on my standalone
Anyone got any opinions 4 me
cheers
lee
I have heard people say that nero 6 has some dvd problems..you can see if you can get an older version 5.5
Or you can try recordnowmax...
I personally use nero but every once in a while I get strange errors so I will use recordnowmax with no problems at all...VERY easy to use.
Scott -
I too had problems but have updated to the latest and all problems I had have gone away. Get the latest update and give it another try.
I started using Nero back when it was 4.xx, still using it in the 5.xx, can't remember burning one coaster due to it including 100's of DVD's. Won't pay for it again though to get 6.xx as 5.xx works for me. Seems my last 3 recorders came with an OEM 5.xx copy.
Nero will burn 4X, DVD Shrink-Nero only 2.5X
By happydog500 in forum DVD RippingReplies: 16Last Post: 4th Jan 2010, 20:49 -
Nero Recode 3.1.2.0 -- "Nero Digital Standard" vs. "Nero Dig
By GrayStrickland in forum DVD RippingReplies: 1Last Post: 15th Dec 2008, 20:23 -
Can I install both Nero 8 & Nero 6 on same machine?
By OzarkBaby in forum Newbie / General discussionsReplies: 8Last Post: 3rd Jan 2008, 22:09 -
need help with Nero 8 and Nero Vision 5 (figuring Extended Play Plus)
By Edward Benavides in forum Newbie / General discussionsReplies: 2Last Post: 31st Oct 2007, 12:10 -
Nero Recode/Nero Digital users...
By siratfus in forum Video ConversionReplies: 4Last Post: 31st May 2007, 06:06
