i was wonderinf if the old flask was able to encode into Svcd b/c it was able to make great vcds and i much dont like the newer verison
thanx for the help
"A good song should make you wanna tap your foot and get with your girl. A great song should destroy cops and set fire to the suburbs. I'm only interested in writing great songs." Tom Morello in Alternative Press
With the bbmpeg plugin you can do it. You can also use the avisynt frameserver and frameserve to any mpeg2 encoder.
ok thanx and how would i do that
"A good song should make you wanna tap your foot and get with your girl. A great song should destroy cops and set fire to the suburbs. I'm only interested in writing great songs." Tom Morello in Alternative Press -
..by reading the guides.
http://www.vcdhelp.com/dvdripping.htm -
What you do have against the newer versions?
The newer versions (0.6 branch) are quite a bit faster than the 0.594 versions (20% faster on my P3 500 for VCD MPEG-1 with Panasonic). Furthermore, you can easily set mark in and mark out points...
Also, it correctly handles some VOB files from DVDs not correctly handled by the 0.594 versions (e.g., Dreamworks DVDs).
Regards.
Michael Tam
w: Morsels of Evidence
how to encode?
By inject0r in forum Newbie / General discussionsReplies: 1Last Post: 7th Jan 2012, 13:12 -
720p encode 700mb and 720p encode 1.5gb or over 3gb
By ali2k1 in forum Newbie / General discussionsReplies: 7Last Post: 26th Aug 2010, 14:09 -
Why do I have to Encode?
By gilamran2 in forum Newbie / General discussionsReplies: 1Last Post: 1st Jun 2008, 05:29 -
Re-encode to HD
By lotsill in forum Video ConversionReplies: 4Last Post: 23rd Sep 2007, 12:03 -
Help with PAL SVCD to NTSC SVCD
By silentmonolith in forum Newbie / General discussionsReplies: 4Last Post: 6th Jul 2007, 07:18
