  1. I have just bought a LG GSA 4040B and updated the firmware (A301 i think). I can burn with Copy2DVD and DVD decrypter but Record Now Max and Nero don't seem to find it when they scan the IDE channels.
    ??? Help!
    Nov 2003
    The Village
    what version of nero?
    • DENON AVR3802/DVD3800
    • Sony JB940 minidisc
    • Bose Acoustimass15 (c/sr/sl/rsr/rsl/sub)
    • Definitive Technologies BP8-06 (fr/fl)
    • panasonic PT47WX51 tv
  3. Question: When you updated the firmware, was the drive set to MASTER, SLAVE, or CABLE SELECT?
    -Yar, matey!-
    Dec 2001
    No. Calif.
    I was using Record Now Deluxe v4.60 (Veritas now Sonic) and the 4040B was good to go. Now updated throught online update to v6 from Sonic.
  5. Question: When you updated the firmware, was the drive set to MASTER, SLAVE, or CABLE SELECT?
    The drive is on as SLAVE.
    I'm using Nero 5.5.??
    and RECORD NOW MAX PLATINUM ??
    (I'll put the exact versions up tonight.
  6. Drive MUST be set to MASTER and should be alone on IDE
    Jolly
