  1. im trying to merge a svcd but tmpg wont take it as it says one cd is different from the other?
    how else could i merge them?is there a tool about that deals with this kind of problem?
    or dio i have to turn them to avi then put them together?
    thank's
  2. I presume you mean the MPEG-2 files from the two SVCD's?
    Have you tried Womble? People seem to swear by that for MPEG-2 cutting/joining etc..
    cheers,
    mcdruid.
  3. did u use a vbr to encode the mpegs? ive only had to do this with avi files with a vbr and used virtual dub to decompress the audio (which was the problem in my case) and then append the 2 files, maybe some1 might know if this is possible with mgegs ive never had cause to do with anything other than avi that were going to svcd
  4. thank's!
    where can i find womble?
  5. Originally Posted by WAK10
    thank's!
    Wimbledon Common of course!
    Sorry - had to be done (not sure if that's a very international joke)
    Go to the tools section on the left, and type womble into the search box.
