Hi everyone. I hope this is the right forum to post this question. Before I start, thank you in advance for replying!
You see, I have two dvd folders, each around 2 GB. They are both vastly different, one of them having 2 audio streams and the other has 3 audio streams. I would like to put both into 1 DVD-R, and I have 2 simple requests.
1. No reencoding or anything that will modify the video quality (whether for better or for worse)
2. I would like to create a menu for the DVD which has 2 DVD folders
I did some searches, and the only solution seem to be using a DVD player which can read 2 separate DVD folders. Is there any other solution? I had this impression that DVDShrink will change the video quality of your video, since it shrinks the DVD to a smaller quality video file. Also, there are more than one audio stream.
Thanks for replying!
DVD with Multiple Audio Streams - Basic Guide
By mustang581 in forum User guidesReplies: 29Last Post: 21st Aug 2013, 03:59 -
Suggestions for DVD authoring with multiple audio streams
By farmkid in forum Authoring (DVD)Replies: 11Last Post: 19th Sep 2011, 17:23 -
HowTo deal w/ nasty "audio streams have diff sample sizes" errors in WAVs!!
By KneeRow in forum User guidesReplies: 0Last Post: 25th Jul 2011, 12:43 -
DVD to MKV with multiple audio & subtitle streams?
By RarelyEvil in forum DVD RippingReplies: 1Last Post: 18th Jun 2009, 10:30 -
Play multiple streams in DVD (Merge multiple streams)
By sebastien91 in forum SubtitleReplies: 0Last Post: 25th Apr 2009, 18:44
