I captured some video w/ iuVCR and the picvideo mjpeg codec - did this w/o pegging my CPU & it seems to have gone well (7200 rpm HD w/ 8M buffer)....I tried to encode this capture file but my encoder complained about the format.
I had seen a post that said that the frame rate wasn't and couldn't be exactly 29.997 fps and that causes problems. I pulled the capure into Vegas & resaved it, then encoded no problem & attributed this to the frame rate.
Does a frame rate problem like that sound plausible? I got by the problem but thought I'd try to resolve it before next time - doing the extra load & save is a bit time cosuming & seems like an extra step (or two).
TIA.
Results 1 to 1 of 1
"As you ramble on through life, brother, whatever be your goal - keep your eye upon the doughnut and not upon the hole."
Every video I make with Handbrake mkv has framerate of 90000 & wont convert
By Onceler2 in forum Video ConversionReplies: 7Last Post: 12th Sep 2011, 11:26 -
Converting a "variable framerate" to constant framerate?
By vieo in forum Video ConversionReplies: 6Last Post: 2nd Sep 2010, 10:05 -
How do I convert xvid framerate 23,967 to xvid framerate 25.000?
By QuickstartDK in forum Newbie / General discussionsReplies: 16Last Post: 4th Nov 2009, 18:57 -
HDV & DV framerate vs bitrate
By turk690 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 6Last Post: 8th Feb 2008, 12:49
