I was looking at the DAC-100 DV Converter and it looks good, but I was curious about something. If I have a Mini-DV Camcorder (which I do) with analog passthrough capability, isn't that the same thing or am I missing something?
I know this is a stupid question and I apologize. I just want to be crystal clear on this before I make any hasty decisions.
Thanks in advance!
Yes, pass through also does the same thing. There is an article on this site as well.
Hello. -
NO - you got it right.......If I have a Mini-DV Camcorder (which I do) with analog passthrough capability, isn't that the same thing or am I missing something?
I use a Canon ZR40 for that exact purpose when i need A/D conversions.
NEVER had an issue, although some will say it "damages the camera". Total BS in my opinion since it is just using the electronic A/D circuits as designed. No head wear. ?! Where can the 'wear/damage' occur?
Grab a firewire card and A/D away
I agree. The advantage of using DAC-100 may be that it allows you to go multisystem (like PAL) plus more input-output options (not always).
Other then that camcorder A/D circuit has the same function and was implemented for you to use it!!! -
Also the DAC-100 most likely tucks away more neatly in your equipment rack than a camcorder would, with all the cables hidden in back, nice compact square shape, lights easily visible, etc.Originally Posted by proxyx99
Capture progressive mini-dv tape on interlaced mini-dv cam ?
By alip in forum Capturing and VCRReplies: 4Last Post: 8th Feb 2011, 18:27 -
What's a used videodata dac-100 worth?
By zoobie in forum ComputerReplies: 0Last Post: 26th Oct 2008, 03:52 -
Have DAC-100, need HD
By The Waco Kid in forum Capturing and VCRReplies: 0Last Post: 21st Mar 2008, 19:41 -
DAC-100 dip switches
By Steinninn in forum Capturing and VCRReplies: 0Last Post: 6th Dec 2007, 21:31 -
How should I know my mini dv cam is shooting a true 16:9
By joy in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 14Last Post: 5th Oct 2007, 13:34
