  1. DVDShrink - Invalid IFO, reason: unknown
    I get this when I point Shrink to a DVD I've ripped in the past in both file and ISO mode.
    Any ideas?
    Oh, what is 'warez?'
  2. Member pyrate83's Avatar
    Alive on XBOX LIVE!!!!!!!
    When ripping in file mode, did u select ALL files. If not, that's your problem.
  3. Shrink can't even open the DVD. It takes a sec then I get "invalid IFO the reason is: unknown" I just tried a different DVD and got the same error.
    DVD Decrypter will rip in file (all files) mode but I get alot of errors. ISO works fine.
  4. install Force ASPI. Open the DVD in a player like Power DVD for a few seconds then try to rip.
  5. i use to get smiliar errors, and in the end (after various testing and mehtods) it turned out to be the dvd-rom drive itself (pioneer 120s). I got an el cheapo drive in it's place, and the problems went away.
  6. the new ASPI layer didn't work.
    raaa
    I guess I'll get a DVD-ROM
    Lite-On 166?
    is that the recomended one?
  7. the 166 is a cheap, yet decent quality and high speed drive. its highly recommended.
  8. i had another drive then saw the liteon-166 at walmart for 45.00. I picked it up because it read the dvd-ram format and can use that to my advantage at times.
    Not sure about rating but so far its working very well and rips pretty quickly
