I've never really addressed this problem, but it's beginning to become a big hassle now. For some reason beyond my comprehension, FlasKMPEG refuses to make good AVI files. Here's what happens:
1. I encode a DVD using the Thunder MISM plugin to read the .ifo, then encode a small 60 second section to test. It doesn't matter what codec I use(I usually pick Divx High-motion, and Windows Media Audio V2). It encodes properly, no warnings or anything.
2. I try to play the .avi file, "Cannot play back the file. The format is not supported." from WMP.
3. I try to edit or otherwise open the file in Virtual Dub, "Cannot determine the file type of <file>"
Am I missing some big thing here cause every way I think about it, it should work.
Results 1 to 1 of 1
What would happen to a subtitle of a movie in mkv format if I split it?
By SunKissUAE in forum SubtitleReplies: 1Last Post: 15th Jan 2012, 07:41 -
what would you do if this happen to you?
By Webster in forum Off topicReplies: 8Last Post: 6th May 2011, 12:23 -
Why does this happen? Resolution problem.
By bananadude in forum EditingReplies: 8Last Post: 14th Jun 2008, 02:47 -
----jerky motion----when did that happen?----
By ozne64 in forum Video ConversionReplies: 6Last Post: 15th Jan 2008, 05:00 -
What will happen to analog cable after the digital switch???
By yoda313 in forum Off topicReplies: 5Last Post: 12th Jun 2007, 18:32
