Anyone here know a good online site to buy 20 ft lenghs of component video and audio cables? Also how about DVI cables for TV's? Thanks...
I can tell you that there is a difference between the two. Although the video and audio cables look the same; same plugs, etc they are not.
I did not believe the clerk at Best Buy and he hooked up a dvd player first with the video cables, which look great. They he hooked up the video using the audio cables. Wha, what a difference. Like DVD vs rabbit ear antenna in the country. Needless to say I bought the video cables. -
I bought two 20 ft component video cables from http://www.ramelectronics.net/html/comp-video.html#c
They had the best price.
Is using S-Video cable better than using RCA cables to capture video?
By snafubaby in forum Capturing and VCRReplies: 21Last Post: 7th May 2020, 08:16 -
Are RCA/composite video cables compatible with audio cables?
By sldvd in forum Newbie / General discussionsReplies: 5Last Post: 15th Aug 2011, 00:17 -
How do I connect my Laptop (VGA) to my TV (S-Video or RCA or component)
By setenay kabardey in forum Newbie / General discussionsReplies: 1Last Post: 3rd Dec 2010, 14:08 -
S-video cable..better to use than RCA Jack audio, video cables?
By snafubaby in forum Newbie / General discussionsReplies: 5Last Post: 3rd Jan 2009, 08:38 -
RCA cables or S-video?
By effects in forum RestorationReplies: 3Last Post: 10th Jul 2007, 06:03
