numerous problems with mainconcept until I uninstalled every codec in my system (windows xp) and used Nimo Codec Pack Build 7.
Install everything in the package except the Huffy.
Before using these codecs, mainconcept would not split files (muxing). I would get Ntdll errors. Plus seem to get other problems with some files when it finished.
Seems to be working great now. But, the company should have made its own codecs with the package. Horrible documentation for this product.
Good luck with the Nimo codec pack, you may be one of the few with no problems when installing it. You might do a forum search for 'Nimo'. The problem is when you install codecs you don't need. They can conflict. If everything works OK, great. If you have codec problems in the future, it may be the pack.
So is any DV codec better than MainConcept at decoding? Does it matter?
By Asterra in forum Video ConversionReplies: 11Last Post: 20th May 2011, 22:59 -
MXF with JPEG2000 codec in Mainconcept Reference
By lord25 in forum Video ConversionReplies: 1Last Post: 3rd Nov 2009, 09:34 -
Unrecognized MP2 codec? *Solved*
By omnikai in forum AudioReplies: 17Last Post: 3rd Mar 2008, 17:57 -
Mainconcept DV Codec in VirtualDubMod
By WinSpirit in forum Newbie / General discussionsReplies: 1Last Post: 14th Dec 2007, 23:31 -
Mainconcept DV Codec Vs. The Rest
By SeeNoEVO in forum Video ConversionReplies: 25Last Post: 5th Jun 2007, 08:16
