Ok I know this is problem comes up all the time...believe me I have read all of the posts about it...but everytime no matter what I do I get an error with the program. I put the priority up for the directshow plugin up, I have have all the proper codecs, I have no clue of what the problem is. Is there any other thing out there that causes errors? I have uninstalled the program reinstalled it, put in a new fresh XP on a newly formatted hdd, I have done it all is there anything else?
I am running a AMD2600+ with 512 DDR400 RAM, with a 80 GB hdd and a 40 HDD. Please someone tell me something...
Results 1 to 20 of 20
Its like wiping your ass with silk.
The Merovingian -
what is the error ? and what are you trying to encode (source file) --
does the error come on loading the file or while encoding ?"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
hmmm, yea, we can't help without a specific question.
LOL, kinda reminds me of the old George Carlin album... his music sounded like crap so he changed his amplifier-200 watts per channel, still crap....changed his speakers to - 50 inch woofers, still crap...... on and on til he finally said
"Hey, maybe it's the needle" -
Originally Posted by Disipha"Art is making something out of nothing and selling it." - Frank Zappa
try to move avi2(open DML) to higher priority.
it works for me.
i do get an error at the END of the encoding, but the file turns out grate
so i just ignor it.HELL AINT A BAD PLACE TO BE -
Thanks for the advice I did that and now I get the ilegal floating decimal point crap...Is there any more advice?
The Merovingian -
All I can say is that these settings work 4 me (see this thread)
https://www.videohelp.com/forum/viewtopic.php?p=693312&highlight=#693312
Also keep away from codec packs like nimo etc.. install only what you need. -
When ever I adjust the settings I get the illegal floating decimal point error which I didnt get before...it sucks because as soon as I get rid of one error I get another...
The Merovingian -
I know there is no bad frames...I have succesfully converted the video before on my old system, which had the same codecs installed and was inferior in everyway. Also the file names are exactly what you specified, I read that one too. I think that I am done with Sh*tgen I think that I will use Main Concept, is there a good guide out there on it, I can make MP2s but the aspect ratio immeadiatley goes to full, and when I use the DVD setting the keep proportions option is greyed out, does anyone know how to keep the aspect ratio with Main Concept 1.4? Thanks
Oh and if you have anymore things with Tmpgenc let me know...I would like to be able to make DVDs without using DVDX COPY express...thanks for all your help people.Its like wiping your ass with silk.
The Merovingian -
Demux the file to a seperate movie only .avi, and audio only files. Only import the video into TMPG, leave the audio to another app. Set your begin and end frames, even if you're encoding the whole movie, tell TMPG where the first and last frames are.
Or
Frame serve from avisynth to TMPG
Code:avisource("movie.avi") or directshowsource("movie.avi",fps=23.976)
If it is only happening with xvid files then change you Fourcc Changer.
Go to start menu --> programs-->xvid then choose avic(Fourcc Changer). Then open up your movie and change Fourcc Description code and Fourcc used codec from xvid to divx. -
I get this poblem from time to time ('Illeagal Floating Point Error' message) for seemingly no reason.
I am normally able to solve it by reducing the 'Motion Search Precision' by a notch or 2. -
I have done hundreds of back ups using Vidomi to convert to Xvid, and would always have one problem or another with TMPGEnc when it came time to convert to(S)VCD.Sometimes frameserving would work,but mostly not, Xvid is highly compressed, and TMPGEnc has problems dealing with any compression. Decompressing your Xvid file with the decompressor from AVI2VCD, and using the decompressed file in TMPGEnc should solve your problem.
Just shut up and listen dumbass -
Originally Posted by Ziffelpig
Sorry I should have been clearer, I meant to mention compressed audio as the problem, I just assumed it was well known that TMPGEnc and compressed audio do not work well together. 99% of the time decompressing the audio fixed my XVID/TMPGEnc problems.
is your system overclocked?? if so reset your memeory and cpu back to their defaults and do the encode... overheated/overstretched memory and or cpu can cause random problems. encode alone, no other progs whatsoever...video and audio seperately.
Fed up with random Sony Vegas errors.
By TMC83 in forum EditingReplies: 2Last Post: 11th Aug 2011, 03:22 -
Pegasys released TMPGEnc Video Mastering Works 5 (aka TMPGEnc 5.0 XPress)
By roma_turok in forum Latest Video NewsReplies: 6Last Post: 24th Jun 2011, 15:42 -
Help! Fed up of blue screen, physical memory dump problem.
By Varchasve in forum ComputerReplies: 10Last Post: 2nd Jul 2010, 09:38 -
difference btw.TMPGEnc 4.0 XPress and TMPGEnc DVD Author 3 with DivX Auth??
By geronemo in forum Authoring (DVD)Replies: 5Last Post: 18th Nov 2007, 15:07 -
Fed up with Cyberlink Powerdirector - Can you help me choose something else
By gayclarke in forum Authoring (DVD)Replies: 5Last Post: 9th Jun 2007, 22:09
