I was using VideoWave to capture full size AVI's (720x480) with no probelm, then I decided to try IUVcr, Longstory short, I decided to stick with Videowave, but when I uninstalled IUVcr (Had to re-install videowave) I found out it would only let me cap AVI's & Mpegs no bigger than 352 x 240. If I tried anything higher I get a visual basic runtime error c+++ library. I occasionally use the avertv program for realtime mpeg capture & that program allows me to cap Mpeg2's at full size but nothing presently on my system allows for a full size AVI capture.
Do I need to re-install something else? BTW i'm running windows XP
