Can someone point me way to find out how to use VirtualDub. I downloaded the latest version but don't have a clue how to set it up to convert DV to a smaller format, if possible to VCD.
yes
check out the guides on this site (HOW TO) - that's how I figured it out- there really is no alternative but to read through and experiment. print out the guides though so you have a reference to hand - then you can add your own notes to help you as well.
scattergun
Virtualdub comand line crashes, but virtualdub works.
By zzyzx2 in forum Video ConversionReplies: 0Last Post: 28th Jul 2010, 14:26 -
Help with VirtualDub 1.9.7?
By hezbag in forum Video ConversionReplies: 4Last Post: 20th Oct 2009, 06:21 -
virtualdub vs others
By dude112 in forum Video ConversionReplies: 13Last Post: 13th Nov 2008, 23:49 -
problem with divx with newer virtualdub and virtualdub mod
By goingape in forum Newbie / General discussionsReplies: 9Last Post: 26th Mar 2008, 18:08 -
Help with VIRTUALDUB Please !!!!
By spliffy in forum RestorationReplies: 10Last Post: 30th Jun 2007, 09:28
