  1. I've been lurking here for a while, lots of good info, but I have a foundation question I've haven't stumbled to the answer for...
    If I purchase a card that has only an analog connection (they're cheaper), can I still plug in my Canan ZR-20 into an existing PC firewire port and still utilize the MPEG-2 encoder to assist the PC in MPEG processing and creation?
    Or, does it have to physically plug into the encoder card to be of any use at all?
    Thanks.
  2. AFAIK, no. The MPEG encoder chipsets will only be used if you are going through the video card. The firewire port will get you a high quality AVI copied from the DV camera to your computer. Then you can use CCE or TMPGENC Plus or <insert favorite encoder here> to encode to MPEG2.
  3. Oh, Big Bummer! Up goes my family DVD project costs.
    I was hoping to go straight to MPEG-2 without extra conversions/time/disk space.
