I have read that most people set the DC component precision setting at 10 bits in the video tab when using TMPGEnc. I have version 2.0 and my setting is at 8 bits and is grayed out so I cannot change it. Why is this and how can I change it? Is the 10 bit setting really a big difference over 8 bit in video quality? Thanks
Hi,
do following:
LOAD->EXTRAS\UNLOCK
now you can change everything you want
-Klaus-
BTW there is basically NO difference whatsoever between 8 and 10 bits. See for yourself
I could be wrong, but I don't think you can change DC precision on mpeg1. Someone correct me if I'm wrong.
correct themamboman
<font size=-1>[ This Message was edited by: zeppage2 on 2001-10-11 10:12:45 ]</font> -
I opened the unlock option as you said and changed to 10 bits, but then when I went to load SVCD format, it changed on me. Is there anyway to maintain the unlock settings while using the SVCD template?
Dell precision 2300
By pantangs in forum ComputerReplies: 0Last Post: 30th Oct 2009, 12:46 -
View intra DC precision
By Bergen in forum Video ConversionReplies: 1Last Post: 14th Aug 2009, 08:20 -
Precision Acoustics powered subwoofer
By johns0 in forum Off topicReplies: 5Last Post: 29th Jul 2009, 20:22 -
Ripped a DVD-R, added file to editor but when loaded to edit, grayed out
By wetcamelfood in forum Newbie / General discussionsReplies: 4Last Post: 26th Jul 2009, 15:06 -
AviDemux 2.5 beta motion precision settings change?
By MilesAhead in forum Video ConversionReplies: 0Last Post: 14th Jun 2009, 15:30
