I've just got SVCD2DVD and installed it and ran fine on the testbed machine on my home network. As everything was fine I installed it on the machine that is devoted to vidoe editing (sorry, but I'm very careful what I install on this machine) and I'm getting the MSI installe running when I try and start SVCDDVD.
So read the FAQ's and found the link to "RemoveMSI.exe" but every attempt I've made either to left click the link or rhight click and "save taget as" has failed. I alo found the same link in an earlier thread on this forum but get the same results.
Help anyone please, I'd be most grateful
Rob
Results 1 to 12 of 12
countrpGuest
countrpGuest
Thank's very much, I think it was My Norton Firewall stopping me picking up the link. I have it now.
Thank's again
Rob -
countrpGuest
Sorry guy's but I'm still stuck. I can't get SVCD2MPG to run on this machine.
Just to confirm it's a Dell Precision 330. Radeon 7500 graphics card, Canopus DV Storm 2, 750mb ram, 2 scsi hd's on an Adaptec 29160N, 1 ide and a cdrom on the mobo primary and secondary and AOpen DVD + burner on a SIIG Ultra ATA 133 PCI add in card. Windows XP Pro patched right up to date. I've confirmed .Net Framework 1.1 is installed, at least according to Add & Remove in Control Panel. I did down load it again just now and installed again so I guess it's there.
I can run the SVCD2MPG installer and everything looks fine. Unzip my reg file into the directory but when I open the program I get the installer running to "configure Microsoft .Net Framework". This stops and say's " The featrure you are trying to use is on a network resource that is unavailable" then gives me the option to specify a location for netfx.msi.
I've done a search and can't find it anywhere. So I "cancel" and get "Error 1706 No valid source code for product Microsoft .Net Framework could be found the Windows installer cannot continue"
So I've run RemoveMSI.exe, fixed the shortcuts and still get all the same stuff when I try to open SVCD2DVD.
I know I must be missing something, I'm just too stupid to know what.
Hope this makes sense.
Regards
Rob -
countrpGuest
Ok so I just made it worse.
Uninstalled .Net Framework and SVCD2MPG. Reinstalled both.
Now I get
Application has generated an exception that could not be handled.
Process id=0x4e0 (1248), Thread id=0x410 (1040).
Regards
Rob -
you could try uninstalling svcd2dvd & .net. Then install .net 1.0 followed by .net 1.1 followed by svcd2dvd.
Pain in the arse but it has worked before for other peepsSVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
What was your process?
email me & I'll send it to you. I'm on holiday at the moment & can't get the link for you.
spumux.exe
By ranee in forum Authoring (DVD)Replies: 3Last Post: 30th Jun 2010, 09:31 -
explorer.exe / drwtson32.exe keeps closing
By coolcoates in forum ComputerReplies: 7Last Post: 28th Nov 2007, 08:42 -
has anyone got the old 2.1 .exe file
By NIPPERLOCKO in forum SVCD2DVD & VOB2MPGReplies: 10Last Post: 27th Oct 2007, 12:35 -
bgsvcgen.exe?
By alegator in forum ComputerReplies: 11Last Post: 16th Jul 2007, 12:06 -
.exe to .avi
By siopawman in forum Video ConversionReplies: 2Last Post: 17th Jun 2007, 20:46
