Is there any freeware out there that'll look at an AVI file and report whether it's top-field-first or bottom-field-first?
No there isnt ... you asked this b4, I think.
Originally Posted by wallywalters
But rabid may be right. My AVIs look the same regardless of the field swap filter... -
Thanks, guys. Another related question comes to mind now. Is it possible that VirtualDub Capture defaults to capturing the same field first *every time*? Or is it random?
Or is this not determined by the software, but the capture card? If so, does the capture card do top-field-first or bottom-field-first every time? Or is *that* random? -
AFAIK, only those cards from Hauppage have "Field" bug. I mean, those
from the PVR lines. I have the oldest version PVR USB from like maybe
3 years ago, and only did 352 x 480. But, this guy had a "Field" order bug.
The other PVR's from that era suffers from this too, but they still do a great
job :P ..just don't run it through DVD2AVI, cause you'll get a bad IVTC w/ it if
you do - though theirs a work-around (I helped someone w/ this issue early
this year on it, and it worked out great) anyways..
Thats about all I know for now
From the Video Workstation of,
-vhelp 2081 -
Originally Posted by FOO
AVI Field Order
By Ash McKenzie in forum Newbie / General discussionsReplies: 1Last Post: 1st May 2012, 00:52 -
Field Order
By Tafflad in forum Authoring (DVD)Replies: 9Last Post: 30th Jan 2010, 00:38 -
Reconciling different Field Order
By vegasarian in forum EditingReplies: 8Last Post: 14th Mar 2009, 11:43 -
Determining field order
By dadrab in forum Video ConversionReplies: 2Last Post: 4th Oct 2007, 15:09 -
Field order?
By miamicanes in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 12th Sep 2007, 16:14
