Hi all,
Though I've read similar threads herein, I have yet to find a suitable fix for my situation. I have a 3.6GB, DVD-ready .mpg plus - roughly - 600MB of additional .mpgs (short movie trailers, a "making of"). This all should total around 4.2GB. However, DVDWS inflates this to over 5GB. Why? (FYI, I cut and rendered everything through Vegas Video 3.0 - a program I've been using for over a year without prior error. Also - as per previous threads - I emptied all excess files from my project folder.)
As a backup, I tried authoring and burning with DVDit and wound up with a similar situation.
Any and all help appreciated.
Thanks!
DVD Workshop is probably re-encoding the file. If the mpg is DVD compliant, then you need to tell it not to Encode compliant files. Can't remember exactly how off hand since I don't use this anymore. Search the forums since this has been discussed several times.
Forgot, DVDit always re-encodes. -
Make sure you check the "do not convert compliant files" check box". Might not be the exaxt wording of that option but close.
Hmm..DVDit never re-encoded of of the DVD's I authored, but I think you have to make the settings match exactly to your projects assets; bitrate, resolution, etc. Maybe I was just lucky
How to convert DVD project to Blu-Ray project??
By zentsang in forum Authoring (Blu-ray)Replies: 0Last Post: 9th Jul 2010, 17:08 -
Passion Project
By mikedub in forum Newbie / General discussionsReplies: 1Last Post: 31st Dec 2009, 14:48 -
DVDWS 2 and Premiere Pro2 and jerky dvd
By paul ward in forum Authoring (DVD)Replies: 5Last Post: 16th Apr 2009, 07:49 -
Help Neeeded For DVD Project. Extract DVD Menu For Use In Personal Project
By sephiros in forum Authoring (DVD)Replies: 2Last Post: 5th Nov 2008, 12:49 -
TeraByte project
By olyteddy in forum Latest Video NewsReplies: 1Last Post: 29th Sep 2007, 00:23
