I have 3 svcd's to combine and make into a DVD.
I have been using this program for awhile and never ran into this problem:
Before I went to bed last night i ran it hoping it would be done in the morning. When i checked it, it was still trying to demultiplex the first file, so it seems like it is freezing there doesn't seem to be much CPU activity.
Can anyone help me on this one?
Thanks.
Is the frozen or just very slow? Slow I've seen if it's over a network.
A program like TaskInfo will tell you the actual size of files even as they are being created so it's useful at times like this. -
well i have done many of these before and they have never taken over 8 hours to demultiplex one file.
this is not over a network, it is local. -
Can you give us some information on the input. like size, audiorate, width, height etc. And if it did some svcd the logging of those.
Greatings,
Yf -
try configuring svcd2dvd to use bbdmux as the demuxer (config menu)
Conversion or demultiplexing of TRP files
By ranmamez in forum DVB / IPTVReplies: 2Last Post: 26th Oct 2011, 08:50 -
out of sync when demultiplexing
By calanda in forum Authoring (DVD)Replies: 5Last Post: 5th Aug 2010, 01:04 -
bd370 stuck
By mosfos in forum DVD & Blu-ray PlayersReplies: 2Last Post: 24th Aug 2009, 20:05 -
DVD Stuck
By tvlreject in forum DVD & Blu-ray WritersReplies: 15Last Post: 2nd Dec 2007, 20:39
