If you want it to be DVD-compliant, it needs to have the IFO/VOB/BUP files. Unless you have a player that plays VOB or MPEG2 directly, then you will have to "author" the VOBs to compliancy.
If your .vob files are all properly joined, which they should be, you can use ifoedit to create your .bup and .ifo files from your .vob files. Just open the program, click on create ifos, and follow the instructions. You can find guides for ifoedit both on this website and on the doom9 website.
recreating vob ifo files
By krohm in forum Authoring (DVD)Replies: 25Last Post: 15th Jun 2009, 05:27 -
What should i do with vob/ifo files?
By waefwaeefwaefw in forum Newbie / General discussionsReplies: 2Last Post: 16th Dec 2008, 01:26 -
Create IFO from VOB w/o IFOEDIT?
By theschles in forum Authoring (DVD)Replies: 1Last Post: 1st Nov 2008, 18:19 -
VOB IFO and VOB, clueless need expert help :)
By Skunk141 in forum Authoring (DVD)Replies: 5Last Post: 13th Dec 2007, 15:03 -
4 separate IFO files > one IFO to govern the full .VOB video
By Salva Veritate in forum EditingReplies: 4Last Post: 20th Aug 2007, 13:38
