  1. Rulle51
    Guest
    Hello there 8)
    Would like to do a request, IF possible ,could the working drive be different than the source, this would speed things even moore :P :P
    BTW I like THIS... I stuff every thing, and I mean EVERYTHING
    in to this baby and it eats it all
    I mix full D1 half D1 different rates, you name it
    and no complaints! YESS
  2. Member ChrissyBoy's Avatar
    Feb 2003
    Yorkshire!
    I wrote a build which allowed multiple drives but it was a nightmare. Because there are so many potential "routes" from start to finish. I got it going but the result was to hopefully reduce processing time. It didn't significantly. I therefore rolled back to achieve more robust/maintainable, less complex code. I'm not going down that route again.
    it shaved about 30 seconds off a run.....
