i dont know which format is was originally, but i had a .bin-file and extracted the avseq01.dat with isobuster. now i have a file that i can only play in powerdvd, windows media player doesnt play it. with another bin i did the same, but extracted with isobuster using the option "extract only m2f2-frames". this ones work fine in powerdvd as well as in windows media player. now i deleted the bin files and want to convert the first movie to a format windows media player can play, but how?
Windows media player should be able to play dat files but anyway just use vcdgear to convert that dat to an mpg.
i dont think so
look ... i used isobuster to extract without any options. as the guide says, this should result in a mpeg2-movie.
the ones extracted with "extract m2f2-frames only" ware mpeg1.
so, how can i convert from mpeg2 to mpeg1 ?
