i have two short dvd movies on HDD. they both play fine on powerdvd. go to TDA to compile these 2 and also to create menus/chapters. have done this many times (w_other movies that is).
PROBLEM: TDA says one of the movies has no audio. it clearly does have audio.
any suggestions? thanks.![]()
I really have no idea but try to encode a small part of the movie with TMPG and see if you can author it. If so then there a problem in the MPEG2. Some time's TMPG can fix MPEG 2 files.
thanks spiderman2k1
what i will probably do is Shrink a small clip from the movie TDA says has no audio, see if TDA still says it has no audio, complie that with the other short movie and create the menus and chaps...then burn dvdrw and see if i get any audio from settop.
TMPGEnc Dvd author 3 problem
By prcole18 in forum Authoring (DVD)Replies: 7Last Post: 7th Oct 2008, 12:33 -
BIG Problem TMPGENC Xpress V.4.4.1.237 + TMPGEnc DVD Author ver.3.1.2.176
By milindb1 in forum Authoring (DVD)Replies: 1Last Post: 20th Aug 2008, 03:41 -
menu problem in TMPGEnc DVD Author 3
By sanduul in forum Authoring (DVD)Replies: 13Last Post: 23rd Oct 2007, 20:20 -
TMPGEnc DVD Author 3 - Playback problem, Help!
By cbales_24 in forum Authoring (DVD)Replies: 2Last Post: 18th Oct 2007, 17:29 -
TMPGEnc DVD Author 3 (MENU PROBLEM)
By jaffacaique in forum Authoring (DVD)Replies: 9Last Post: 18th Sep 2007, 20:43
