I have searched the archive of this group, found others getting this error message and still do not know how to resolve this. Advise?
I am encoding with Quick Preset to VCD.
This default set Video Codec to MPEG1 (.MPG) (mpeg2enc)
I am using a VIDEO_TS folder from a couple of folders deep on the hard drive.
When the Progress window comes up, it says failed and clicking the info button I get the error message below.
If I change the Codec to (ffmpeg) I do not get the failure.
The initial install of ffmpegX was done using the install instructions and downloads as directed.
1. How to correct this error?
2. What would be the difference between writing a VCD or DVD for standalone player between these two Codec? why use ffmpeg vs mpeg2enc. Since the default quickset choose mpeg2enc I thought that might be better.
INFO: [yuvscaler] yuvscaler (version 1.7.0) is a general scaling utility for yuv frames
INFO: [yuvscaler] (C) 2001-2002 Xavier Biquard <xbiquard@free.fr>
INFO: [yuvscaler] yuvscaler -h for help, or man yuvscaler
Sat Nov 8 14:39:17 EST 2003
usage: movtoy4m -w width -h height -F a:b -a a:b [-s] [-f] [-o ppm/y4m] movie.mov
example: movtoy4m -w 352 -h 288 -F 25:1 -a 4:3 pal_normal.mov
example: movtoy4m -w 352 -h 240 -F 30000:1001 -a 16:9 ntsc_wide.mov
**ERROR: [yuvscaler] Could'nt read YUV4MPEG header!
**ERROR: [mpeg2enc] Could not read YUV4MPEG2 header: system error (failed read/write
Harmonz
AnonymousGuest
VIDEO_TS to mpeg-1 is not supported in the current version (you should use VOB input). VIDEO_TS input is supported when converting to mpeg-2 or mpeg-4.Originally Posted by harmonz
For VCD encoding, ffmpeg is better and faster, but it does not create fully compliant streams (eg. it produces VBR mode streams with short high-bitrate peaks). Some DVD players will not accept such streams. For VCD encoding, mpeg2enc is slower but fully compliant to the VCD standard with CBR streams.Originally Posted by harmonz
You must first make sure that Quicktime Player is able to open your source. In your case you probably miss the Quicktime mpeg-2 player component.Originally Posted by harmonz
ffmpegx can't locate mpeg2enc
By sarmen2 in forum ffmpegX general discussionReplies: 10Last Post: 11th Sep 2015, 05:32 -
Error on ffmpegX
By affonsohnunes in forum ffmpegX general discussionReplies: 9Last Post: 15th Jan 2010, 08:21 -
DIV16B_KEY what does this error mean at ffmpegX
By joachino in forum ffmpegX general discussionReplies: 1Last Post: 12th Feb 2009, 09:33 -
ffmpegX mpeg2enc compiling problem
By dubis in forum MacReplies: 5Last Post: 12th Sep 2008, 16:54 -
ffmpegX not accept mpeg2enc
By aviary99 in forum MacReplies: 1Last Post: 29th Jun 2007, 22:02
