Greetings to all,
Two days ago, I took upon me the hefty process of transferring wonderfuldays.avi to dvd... All seemed to work just perfectly, although I had to wait (well, sleep) for almost 17h for the process to be completed (avi => mpg with subs => m2v).
And then, the shite started raining on my poor belgian head... the "VOLUME I" folder is too large ( by ten mb or so ) to be burnt onto a dvd!!!
Really, is there no alternative for me but to redo the 8.30h lasting conversion process?
Any help would be deeply appreciated...
PS: Is it normal that the audio_ts folder is empty?
Yes - but what is normal anyway !Is it normal that the audio_ts folder is empty?
HUH ?!.......the "VOLUME I" folder is too large ( by ten mb or so ) to be burnt onto a dvd!!!
You mean VIDEO_TS ??? . What is Volume I?
Continue .... author... use DVDShrink to fit .
Uhm... ...down !
DVD Authoring with Windows MM 2.6 OR AVS Authoring
By jagman in forum Authoring (DVD)Replies: 3Last Post: 8th Oct 2011, 05:41 -
DVD authoring ac3 out of sync after authoring but not before
By Genaugmen in forum Authoring (DVD)Replies: 1Last Post: 29th Jan 2010, 20:16 -
TMPGEnc Authoring Works v.4.0.4.24 - Authoring
By niteghost in forum Authoring (DVD)Replies: 8Last Post: 21st Jul 2009, 22:15 -
Great Article On Current BD Authoring Solutions & Future Mac Authoring
By videopoo in forum Authoring (Blu-ray)Replies: 1Last Post: 12th Dec 2008, 18:04 -
TMPGEncDVD authoring 3 with divx authoring
By buttzilla in forum Authoring (DVD)Replies: 0Last Post: 11th May 2007, 22:51
