Hello all,
I've got a power calibration error when i start burning a DVD-R. It concerns Ritek G04 disks (Ritek is the brand) at 4X only. However they work at 2X. I tried another brand, TDK, which have worked each time at 4X. I tested with both Nero 6.0.0.23 and Nero 5.5.10.X. The firmware is up to date (1.08). Anyway i tried all of them, official and unofficial, since 1.05. Ritek G04 medias are supposed to be supported at 4X since this version actually.
I could burn my Ritek G04 at 4X only a very few times. Some people having the Nec 1300A have already reported the exact same thing as me. But for most people, there's absolutely no problem. I don't understand why it worked 2-3 times only and why TDK disks have no problem for burning at 4X. Yes, i could change the disks but TDK costs around 5 € /media which is almost 4 times more expensive. Plus, Ritek G04 disks are reported compatible on almost 100 DVD players !
Would you think the issue is hardware ? I'm doubtful. I read somewhere the problem may be the power supply or the temperature. My burner is on secondary master (alone). I wonder if it's possible. On the system side, all my drivers are updated, XP too. Everything is stable so i'm kinda lost there.
Any help appreciated.
I have burned about 50 RITEK G04's in my new 1300a and had no issues. They burn great at 4x. OEM Firmware (drive was manufactured less than 90 days ago), Nero 6.0.19
1) Are they true RITEK G04's, or could they be fakes?
2) Do you have UDMA enabled?
3) Kill your virus scanner
4) Can you burn an ISO with DVDDecryptor (I can't, newest version barfs with buffer underrun)?To Be, Or, Not To Be, That, Is The Gazorgan Plan -
1/ Yes, they're true Ritek. I am sure.Originally Posted by Gazorgan
2/ Yes it's enabled.
3/ I don't have one.
4/ I haven't tried DVDdecryptor. Actually, i need to burn from hard drive only (DVD ROM and mostly DVD Video).
Thanks. -
The drive uses so-called - ACTOPC – dynamically monitoring writing power and reflection of the media in use, calculating the optimum laser power and adjusting it to real-time.
So, it would react to inconsistent media quality and adjust laser power output AND rotational speed if the media doesn't meet reflective expectations.
One of the reasons I got the NEC myself :P
Where Are these Ritek CD-Rs Made???
By NBK2 in forum MediaReplies: 19Last Post: 19th Aug 2010, 14:32 -
Ritek: NEVER EVER AGAIN
By mrlar2 in forum MediaReplies: 50Last Post: 15th Aug 2007, 04:13 -
Ritek CD-R White Printable Quality
By mmbetz in forum Newbie / General discussionsReplies: 4Last Post: 18th Jul 2007, 21:32 -
NEC NDH81
By babagoi in forum DVD & Blu-ray RecordersReplies: 0Last Post: 24th Jun 2007, 20:05 -
Ritek Ridata DVD-R 4X G04 where or better?
By Illicious in forum MediaReplies: 8Last Post: 15th May 2007, 11:41
