Hey all,
I just got an HP DVD-300i. I used the included DVD creator software to burn a short DVD+RW. I then played that DVD+RW in the drive with PowerDVD and it worked fine. I then took the DVD+RW over to my XBOX and tried it. The XBOX said that it was an incompatible disc.
Does the XBOX look for a certain bit setting on the disc? HP offers a "Compatibility Utility" on there website which it says can change the bit settings from 1 to 2 or 2 to 1 on the drive or on a DVD+RW. However, when I use the utility it does neither. I get an error message saying it cannot change the setting on the drive or disc. I have tried other discs (Memorex) and have the same problem.
Anyone know how I can use this burner to make playable DVD's for my XBOX?
Tried Nero or DVDInfoPRO or different medias or different settings?
You stop me again whilst I'm walking and I'll cut your fv<king Jacob's off. -
I tried DVDPRO but it gave the error message "Drive does not support bit setting" when I tried to change the disc to DVD-ROM.
I will have to load Nero 5 and try that. The switch on the screen clip shown in the post above is interesting. I have never seen a "force XBOX compatibility" setting before. I wonder what that switch really does? and why don't other DVD burning apps have this switch?
Black Magic Intensity Pro: Issue with xbox 360 settings
By dreamboss in forum Capturing and VCRReplies: 2Last Post: 14th Mar 2012, 20:50 -
What are best convert AVI settings for XBOX 360
By traveler31m in forum Video ConversionReplies: 5Last Post: 1st Mar 2010, 06:59 -
Lots of question regarding conversions, bit rate, Xbox 360...
By walterdavid in forum Newbie / General discussionsReplies: 2Last Post: 20th Nov 2009, 23:06 -
Changing NAT Settings On The XBOX 360
By Nitro89 in forum Off topicReplies: 0Last Post: 8th Nov 2008, 12:49 -
Ashampoo - UDF Settings to make Disc readable on XBOX?
By snowbound in forum Newbie / General discussionsReplies: 1Last Post: 24th Sep 2008, 15:58
